RCU Forums - View Single Post - What is this part?
Old 08-11-2008 | 10:18 AM
brett65's Avatar
brett65
My Feedback: (18)
Default RE: What is this part?
ORIGINAL: cappaj1
ORIGINAL: Spetz
Ok, I want some of these:
http://www3.towerhobbies.com/cgi-bin...?&I=LXD930&P=7
But the ones where the skinny bit that comes out of them is threaded and I can secure it with a little bolt, if that makes sense.
Does anyone know what they are called or can link me?
Thanks in advance
I've never found any that are threaded but that's how they SHOULD be!
I purchased the type you have a link to but couldn't use them as the skinny bit you mentioned is fatter than the original ones that came from SIG and I didn't want to drill the holes larger.
No they shouldn't be! That's what my World Models Skyraider came with, and the finger nut would fall off after a flight. It wouldn't stay tight because the back and forth movement of the servo arm always made it come loose. I got the dubro connectors and the problems went away.
