ORIGINAL: MPevine11
it runs at 210
from what i hear you can run it at 270?
if i make it run @ 270 will i get more power from my 3.3?
how should i do it if so? alsi when i pinch the fuel line to shut it off, it dies after like a sec w/o speeding up first, how do i fix that?
You can run the engine at 270, most engines anyway. If your a beginner, try to get it around 230, or 250 degrees, for starters, to be on the safe side. Why does an engine have to have a timelimit, before it shuts down? I don't have a Rustler, but a RC10GT, I shut the engine down with the throttle trim on the radio, works fine. To burn the excess fuel in the engine, I keep the carberator closed, apply the glow starter, put it on the starterbox and burn the remaining fuel out the engine.
Am I missing something?
