Rustler temp/tuneing help
it runs at 210
from what i hear you can run it at 270?
if i make it run @ 270 will i get more power from my 3.3?
how should i do it if so? alsi when i pinch the fuel line to shut it off, it dies after like a sec w/o speeding up first, how do i fix that?
it does. The time for shut-off should be in 2, 3, or 4 seconds. 3 is optimum. try richening it to get to 3 seconds and see if it speeds up.
If you have anymore questions feel free to ask me.
Banned
ORIGINAL: MPevine11
it runs at 210
it runs at 210
Am I missing something?
ORIGINAL: Pearl_414
You can run the engine at 270, most engines anyway. If your a beginner, try to get it around 230, or 250 degrees, for starters, to be on the safe side. Why does an engine have to have a timelimit, before it shuts down? I don't have a Rustler, but a RC10GT, I shut the engine down with the throttle trim on the radio, works fine. To burn the excess fuel in the engine, I keep the carberator closed, apply the glow starter, put it on the starterbox and burn the remaining fuel out the engine.
ORIGINAL: MPevine11
it runs at 210
it runs at 210
ORIGINAL: Jozachar
richening is counter clockwise?
ORIGINAL: MPevine11
ORIGINAL: Jozachar
thanks for the help man i will try this tommro if it isnt raining
also does hitting a curb full speed with a 4-tec 3.3 count??
lol
lol
ORIGINAL: MPevine11
lol
lol
WA
ORIGINAL: MPevine11
[/quote]
[/quote]
the traxxas motors have peak power at about 275 degrees... but yes, for a begginer that would be optimal temp
