ORIGINAL: jalbala
Which switch on the 7202 is used to control the trainer mode? and does it need to be programmed that way?
Any chance you have read the manual?
http://www.horizonhobby.com/ProdInfo...o_Manualv2.pdf Page 38 tells how to set up the trainer section and the switch is clearly labled on the top left of the box above the stick.
