covering
It's trans blue Mono and Ultra checker and yellow. I did the whole plane in trans first. Then I cut my "gothic" flames out of checks. Then I took the backing from the flames, outlined them on the back of yellow, cut the jaggy edges and cut the inside and ironed them on.
The trans is the same as the normal. You can get pretty sloppy with the innitial ironing and then get it tight with the heat gun. I could have left it trans blue and checks and it would have looked great. I just wanted to do this to see if it would look as good as the prototype photoshop image.
Now I have to stuff it (engine, electronics)!
