HELP! question about a bawky Thunder Tiger
I don't know your carb but if it's got leaky O rings on the needle as pikebishop mentioned then your muffler pressure will be forcing fuel past them which could be the spray you're feeling. In other words, fuel isn't getting into the carb which makes it run lean. Also check to see if the idle needle is clear of the main jet at full throttle. Make sure there's no blockages inside the carb.
