RCU Forums - View Single Post - Help with new ESC
Old 08-13-2008 | 10:18 PM
pooka2hot4u
Default Help with new ESC
Hey, as some of you may know, I recently got a King 2 heli, fried the motor and ended up getting a new 3900 Brushless motor and ESC for it.
The ESC is a Dynam 30A brushless ESC
http://www.helidirect.com/product_in...oducts_id=1298
It seems to work fine and all, but I have one weird problem with it.
The manual says that the first time you install it and power it up, it's supposed to make these 3 (or 4, forgot) beeps to configure itself and whatnot and then it's ready to go. Mine does this every time I plug in the battery to run the heli. The manual says that it's only supposed to do that the first time and that's it. Any thoughts?
Another thing I have a problem with is the stock gyro. When you power up the heli, it's supposed to blink the red light for a while to set up and then a steady light shows it's good to go.
However sometimes it just won't stop blinking. Meaning I get absolutely no control of my tail rotor. This seems to mostly happen when I move the tail blade servo a bit more to the rear of the boom than it comes out of the box. I need to do this to try to tune my tail rotor, it never seems to have enough thrust by itself to counteract the main rotor. I always have to add to it with the stick a bit, even at full trim.
