Electrajet - looking for advice and feedback
I have an Electrajet with an e-flite 16 amp speed control.
The low voltage cut off doesn't seem to be functioning. I was doing some testing in the house to see what kind of battery run I should expect. I expected the motor to cut off around 6 or 7 minutes, but at 9 minutes the blade was turning very slowly. Clearly the low voltage cut off did not kick in.
There were no instructions for setting up the ESC. Where can I get instructions for this ESC. e-flite efla100.
Or, can you advise me what I should do? Is there a set-up procedure I need to follow?
Perhaps the ESC is defective.
Thanks for your help.
