RCU Forums - View Single Post - CMP giant scale Zero build
Old 08-15-2008 | 03:59 PM
  #154
BOLD PILOT
My Feedback: (159)
Default RE: CMP giant scale Zero build
Once you get used to flying this bird. you will have no trouble. I would suggest the first few flights at a larger field so you can get the feel of the take off and landing. I believe the landing will give you a challange. The plane is a floater at 21lbs. Flaps are a required, with a little power to bleed off airspeed so you don't tip stall. Don't forget about 1/8 down elevator with full flaps.
cheers,
Bold Pilot.
