RE: Tx/rx compatability question
I will make this asumption
You are referring to an aircraft system, 72 mhz FM, set to PPM mode.
JR transmitters are positive shift.
Hitec receivers are available in positive, negative, and select shift versions.
So, the answer is "Maybe."
