RE: Byron Wedell Williams Racer Build
Thinking ahead I wanted to install the Antenna tube before the stab. Much easier to access and move the fuse around. Using the covering heat gun I bent the 36in tube and marked out it's run. The fuse was prepped and the tube sanded for adhesion. Tube then tack glued with thick CA then epoxied with fiberglass cloth.
Pete
