Well I'll admit I was intimidated about using Koverall having never used it before but it's just about the easiest covering I've worked with
Stab and elevators were final sanded the given a coat of Stix-it. While I didn't take the temp of the iron I had it set well below the temp for Ultracoat. The material shrunk nicely too. The covering under the overlapping seam was coated with Stix-it then covered. Two coats of nitrate dope and done.
Reset the fuse and checked for level. Final fit and sanding of the stab for 0 incidence. Tac glued with thick CA. Fiberglass and epoxy both sides of the stab. Epoxied the dowel spacer for the flying wires. Will seal up the tail next.
Pete
