RE: Byron Wedell Williams Racer Build
Last work for the weekend[8D]
Vertical stab trailing edge had already been fitted. I had trouble getting it out and adjusting so I bent some wire and with tape held them in position. This allowed me to pull the balsa forward to adjust depth. When the epoxy sets I'll push them through and they will fall into the fuse. Made a couple of compression brackets per instructions. Epoxied the TE in place and checked for level.
Pete
