RE: Predator Outrigger Project
That is exactly what I put in my roundnose -the teflon tube had to be sanded a little to fit in my stuffing tube.I made my own strut bracket which is not hard to do.You need some silver solder to assemble the flex to the solid shaft.There is enough flex to make an extra shaft should you need it.May not be beefy enough for brushless but is fine for 500-600 size brushed setups [I don't use brushless].[8D]
