Last line of which question in the faq. When the switch is on I get downward movement. But I want downward movement when the switch is centered and no movement when the switch is off.
ORIGINAL: Krysta
You may want to try as the last line says in the FAQ "Just remember that if your flaps do not deflect downward, you may need to change your rates to negative."
This sounds like what you will need to do to fix this
Sincerely,
Krysta
Product Development & Support Specialist
Futaba Service Center USA
[email protected]
