ORIGINAL: Sukhoi4Me
No Tom I didn't. FMA said I needed "node connectors" even after I explained the exact set-up. So what else do I need?
Just put a female servo end on the node connector to make a charge cord. That's what I do to make the charge cords that I supply with the charger.
On the node connector red is + power, black is ground and the white wire next to the black wire is the balance wire and goes to the signal (yellow) wire in the servo connector. The other two white wires can be removed, they are balance leads for 3 or 4 cell packs which you do not have.
TF
