RCU Forums - View Single Post - Phase 3 EF - 16
Old 08-20-2008 | 09:23 AM
  #49
BaracW
Default RE: Phase 3 EF - 16
I am no expert, as I have only just got mine to flying status, however, stock specs call for a 3S battery in the 1800-2200mah range. I'd say if they are 15C or better, you should be in good shape as is. You'd only need to change the ESC if you swapped motor or fan to a higher amp drawing combination. Stock, from my research, draws about 24 amps max.
