RCU Forums - View Single Post - evolution 52 problems
Old 08-20-2008 | 12:14 PM
blw's Avatar
blw
Default RE: evolution 52 problems
First, put in a hot plug like an A3 to see if it will burn the fuel more efficiently. The OS 8 is too cold.
Second, readjust your low speed until it idles for longer than 30 seconds and will take a reasonably advanced throttle without stumbling or wheezing. Then, peak your highspeed needle.
I bet there is a good chance that your engine always sounds cold when cranking and first advancing the throttle. This is a common characteristic of Evolution glow engines with OS 8 plugs.
