Having problems setting the throttle on my seamaster
I can't seem to get the throttle right on my seamaster. When the barrel is completely closed it is only 1/2 way on the throttle to wide open. I have the servo in the shortest hole and the carb lever in the longest hole. Fiddled with this thing for over an hour. If I set the End Point Adj over 100% I can get it to function OK. Can you go more than 100% without damaged to the servo?
