RCU Forums - View Single Post - CA Model Epsilon 90 building thread!
Old 08-24-2008 | 06:52 PM
  #42
betatester21's Avatar
betatester21
Default RE: CA Model Epsilon 90 building thread!
Tank installation...
Using several strips os Scotch's double sided tape, I've applied two pieces of foam both to the tank support and to the top of the tank compartment. Also mounted the tank using Velcro strips.
Of course, the tank plumbing was previously done. I wanted to keep the hoses as short as they can be. I've also replaced the standard clunk by a filtered one, made of sintered brass.
Once this was done, I routed the throttle cable through the firewall and the tank compartment. This can be tricky, if you don't want to keep the throttle servo draining large current amounts.
Pics:
ID:	1018633   Click image for larger version
ID:	1018634   Click image for larger version
ID:	1018635   Click image for larger version
ID:	1018636   Click image for larger version
ID:	1018637   Click image for larger version
ID:	1018638   Click image for larger version
ID:	1018639   Click image for larger version
