RCU Forums - View Single Post - Electric starters: the horror!
Old 05-28-2003 | 07:47 PM
Montague
Default Electric starters: the horror!
What made you think of loosening the glow plug? I have heard of engines that had too high a compression when out of the box, the usual "fix" for this is to put in two of the little washers under the glow plug until the engine has run a bit, then you can take one of them out. It does sound like your engine had overly high compression at first. Not a bad problem to have, in the grand scheme of things.
