RCU Forums - View Single Post - Flybar removal question....
Old 08-25-2008 | 08:12 AM
mcinturf
Default RE: Flybar removal question....
Thanks for all of the help and info everyone. Damn... I could never get the aluminum hub screws out to replace my flybar. Ended up stripping one so bad I couldnt even turn it with precison drivers or needle nose pliers. Guess I'll just get a new hub ( I can get the the allen wrench screw out) and keep this one for a back up. It's not really that bent. As for the body kit. I bought another rear. I really am getting good enough to fly without wrecking too hard anymore providing I'm not flying in any sort of wind outside. Both gears seem fine and they turn smoothly. I think if anything is causing vibration its the flybar, gain or possibly a slightly bent inner shaft. I'm hesitant to try to take the shaft out though. Havent had much luck in removing various screws. Those yahoos at the hobby shop really put some of them on tight...hence my stripping one of the hub screws. Oh...and has anyone bought the E-flite pack of screws and knows if it has replcement screws for the aluminum inner shaft hub?
Thanks again.
