RCU Forums - View Single Post - servo horns
Thread: servo horns
Old 08-25-2008 | 02:48 PM
brett65's Avatar
brett65
My Feedback: (18)
Default RE: servo horns
ORIGINAL: RCKen
ORIGINAL: brett65
WOOPS! Mine are all in upside down then. They have a little give when I really tug on them, but I don't think I'm gonna have any type of failure.
Brett,
Unfortunately you are setting yourself up for more failure than you can possibly imagine. The setup of the servo grommets and the brass insert is designed to isolate the servo from the vibrations that are present in the airframe. If they are not set up properly those vibrations will transmit directly from the airframe to the servo. Vibration is the mortal enemy of electronics, and will kill a circuit board. It can also destroy the gear train in the servo. If your servos are setup incorrectly trust me that it's well worth the time to go back and install them properly. Otherwise you will probably be taking your plane home in a Hefty back sooner or later.
Ken
I guess I'll be pulling servos tonight[&o], better safe than sorry. Thanks Ken.
