RCU Forums - View Single Post - another beginner building question...
Old 10-15-2002 | 03:06 AM
FHHuber
Banned
Default another beginner building question...
You've not glued it on? No problem. Set the impropery cut piece aside, and cut the correct piece of sheeting, trim the turbulator spars ( the 2 smaller ones on top of the forward 1/3 of the wing) and don't forget ti inset them into the sheeting as illustrated (4 to 10 times the strength of a butt-joint)
The miscut piece will work as a piece of sheeting on the other wing... the portion behind the main spar uses narrower sheeting. [img]i/expressions/face-icon-small-wink.gif[/img]
Don't short-change structure on the wing, especially near the center.
