RE: the hyper st PRO thread!
what shock/damper set-up do you guys run in the Hyper ST's?
- what pistons?
- How much weight shock oil?
- what springs?
I think I'm going to change to: 4 piston hole (white color) and 35wt oil, is this a good set-up?
And if you want to run with the black pistons with 2 holes what oil do you use? cuz if you use the 2-hole the susp. setup is softer.
which springs fit on the shocks?
