RCU Forums - View Single Post - Question on installing landing gear
Old 08-27-2008 | 08:17 PM
flyX
Default RE: Question on installing landing gear
makesure you mount the gear to have proper toe in, before you drill.
Your idea is okay. You can use bind nuts and trim the nuts if you have a drimel .
So it'll clear the servo
I usually just add tri stock to the side of the fuse also
