RE: Byron Wedell Williams Racer Build
Still waiting for parts...
So worked on the Tailwheel. You need to solder a #4 washer to act as a weight bearing surface for the tailwheel bushing and for the tire. Then drill out the tire hub with a #29 drill bit. File a flat spot for the collar on the tire and the steering arm as well as using blue locktight. Last is to install the 2-56 threaded ball links in the outer holes of the steering arm.
