RCU Forums - View Single Post - Byron Wedell Williams Racer Build
Thread
08-27-2008, 09:09 PM
89
Rocketman612
My Feedback: (
85
RE: Byron Wedell Williams Racer Build
Was going over the servo layout for the Rudder, Elevators and Throttle. Going left to right the plans call for the Rudder servo then both Elevator servos then the throttle servo. The Rudder is setup as a "Pull-Pull" with it being off to the side I think the geometry will be off and it will bind or stall the servo. I was under the impression the servo should be in the center with the pushrods coming off equidistant to the Rudder horns. The photo show the alternate setup going left to right is Elevator, Rudder, Elevator then throttle servo.
Any comments welcome.
Pete
The second photo is of the stock layout you can see the Rudder setup at the top with the two Elevator servos in the middle.
Reply
Like
Rocketman612
View Public Profile
Send a private message to Rocketman612
Find More Posts by Rocketman612
View iTrader Profile
