ORIGINAL: schnipster
a friend of mine has one....2 things
first =make sure your drive sytem is straight out from the back not trimmed up, this makes that boat run unstable
second=the adjustable trim tabs need to be straight out if not about 2 mm down from straight out inline with the hulls running surface
both of these items will push the nose down a little and i seems to work...not a pro just seen what my buddy did
if your boat is runing wet,(and it is!)then you need to do the OPPOSITE of what is quoted above,as this info will do nuthin but force your bow down even further....
post some pics of your set-up inside and out,including the transom hardware w/different angles.... [8D]
