RCU Forums - View Single Post - Scale Propeller Availability
Old 08-29-2008 | 12:38 PM
abufletcher's Avatar
abufletcher
Default RE: Scale Propeller Availability
Too true! But then a stained and "gussied up" Zinger will have pretty much the same effect. Below are a dummy prop (of scale diameter and shape) and a prettied up flying prop I made for my Snipe. However, given that the original Snipe props were painted grey almost down to the hub, I guess an all grey APC prop wouldn't look too bad. Actually, I plan to use the same 13/6 APC prop I used for all my engine break-in on the maiden.
ID:	1021635   Click image for larger version
