RCU Forums - View Single Post - Charge New Batt.
Old 08-29-2008 | 01:21 PM
jehawkjr
Default Charge New Batt.
One question, probly need several answeres. I have the Bantam BC6 charger. Its set up for a 11.1 3s 2200mah pack. I now have a foamy which has a 1320mah 11.1 3s pack. It asks you what type of batt. easy lipo. Then it ask you what volts. 11.1. Third it ask how many cells. Bam! 3. Now your ready to charge. So I start, while charging you can scroll through the charger and it shows you the temp cut off. Timer which is set at 120 sec. and here is were it gets tricky. It shows a max charge and its set at 2200mah. I dont know how to change it. Not sure what it means. Is this how the charger knows the pack is full. If so its too much for the 1320 right? What else do I need to check to make sure the pack dont blow up on me.
