RCU Forums - View Single Post - DL-50 engine
Thread: DL-50 engine
Old 08-29-2008 | 08:55 PM
  #2737
krproton's Avatar
krproton
Default RE: DL-50 engine
ORIGINAL: switch26
thanks for the compliment Tim,i agree with you,Great planes should of never stop production on this beauty of a plane,well hey i already posted the engine install pictures but ill doit again soon,just give me a chance to take the cowl apart,i made my own spark plug wire clip to hold it from swinging around,i could of went with something very simple from the hardware store but im way too picky and didnt like what they had,the outo parts store have the spark plug wire looms but still not good enough for the price,
anyway i had to drill a 1" inch hole on the firewall for the proper air flow for the carb,i wound a couple turns of fuel tubbing to hold enough fuel in the line in case i deside to go on a vertical downline so the engine doesnt quit,the GP pitts has a very different way of mounting the fuel tank and the firewall has very limited space for anything,i hope the next giant scale plane i get is not as complicated as this one to convert to gas,
this plane was design with the nitro engine in mind and the manual doesnt include instructions for the gas engine,i also had to relocate the throtle servo and re-enforce the engine box to accomodate the DL 50,well anyway the build went well and i should maden thins beauty soon,ill try to get some footage if i can and will post here for every one to see,dont expect much though im not very experience with planes but will try to keep it safe and fun as posible
Hi Switch.
Hey, don't go taking the cowl off just take more pics! If you want to post pics, just post the ones you already have again (you saved them in your computer, right?).
I think most of our recent stuff is easier to setup for gas as we are getting into that more and more.
A few years ago I had to do some vibration testing on an engine. We mounted a prop with one of the tips cut short onto a Pitts we had leftover from development or something. Anyway, I had to go out and fly the Pitts all day long and it was surprisingly easy to land - let alone fly and takeoff. When I was asigned the Christen Eagle project (which is the same basic airframe as the Pitts) we found that the C.G. could be moved farther aft. What I'm saying is when you balance your Pitts at the recommended C.G. this will be a good thing because she will be plenty stable for your first flights.
Let us know how it goes!
Tim
