RE: Trainer cord set-up
It may be that you have used your trims on the master to center the servos.Put trims at neutral,check to see if servo output arms are at right angles to servo. If not remove arms, rotate them to get them that way; then adjust linkages. If now the buddy box still doesn't allow sufficient adjustment with it's trims something definitly wrong with that buddy box.
