35% Cap 232 3-D Setup
I just picked up a 35% Cap and I'm setting it up. I want to set it up for 3-D. The control surfaces are not double beveled and the max throw I can get on the ailerons is 30 degrees and I can get about 40 degrees on the elevator. Not sure about the rudder.
For those doing hard-core 3-D with your Caps, how did you set up your control surfaces? Should I even consider cutting into the stab to get more throw on the elevators? Do some builders choose to double-bevel?
