RCU Forums - View Single Post - Engine oils
Thread: Engine oils
Old 08-30-2008 | 07:09 PM
Boomerang1's Avatar
Boomerang1
Default RE: Engine oils
Hi David, I'm also using DTE light in Wrens (SS & 44) with no problems whatsoever. Look up the company Lubes Direct located at Penrith NSW, a Mobil distributor.
Last time I bought it it was about $90 including delivery for 20 litres. The only down side with the DTE light is the colour, it has none! This makes fuel levels a little harder to see.
I did try Castrol TTS oil 2 stroke as recomended by Wren but I do not fly as often as I would like & had problems with gummy bearings which the starter would struggle with on the first start of the day. - John.
