I have used acetone to remove it. Keep it away from seem in the covering. Melts the glue real fast. I used a Q-tip to rub the Ca off the covering.
Besides getting the glue off the covering, try this method. Can you see it when it is in the air? If not, try not to worry about it.
Dru.
