RCU Forums - View Single Post - Cx2 Mods And Pics
Old 09-01-2008 | 12:14 AM
J-MICHAEL's Avatar
J-MICHAEL
Default RE: Cx2 Mods And Pics
They both look great guys ! Hey Skyblue, your fuselage is probally one of the best I've seen. Don't worry about the skids, you can tweak with that in time...... To help blend in the white Xtreme skids with the gray fuselage, you can always Dye it gray or black or whatever with some RIT dye. Wal-mart carries it along with other stores. You know, the stuff you can use for clothing and such....Anyway, just thought I'd throw that out there. I know there is a procedure for that, just do a search here on the E-Flite forum. I do remember you had to boil it for the desired color, and then cooling it.
Also if ya ever want to convert your blue CNC stuff back to silver for a even more realistic look you can use some Heavy Duty Drain Opener by Scotch, it has Lye in it that will make the blue into a shiny silver. Go here for the procedure if ever interested
http://www.rcuniverse.com/forum/m_74.../anchor/tm.htm
Have a good one guys,
~ Jeff
