ORIGINAL: jaka
As I said ! acetone will not remove dried CA at once...neither will nitro .
That's not what you said...
you said acetone will not work.
ORIGINAL: jaka
But! Nitro will remove dried Ca glue much faster than acetone.
Acetone takes an awful long time to desolve Ca glue compared to nitro.
I disagree. I've tried both.
"Soaking" CA in Acetone does the best job and works rather quickly.
Usually the CA becomes putty like in 5-10 minutes of soaking, and then can be easily removed using the Acetone-toothpaste method.
They key is to keep the Acetone from evaporating.
Try it sometime. There is a vast difference using acetone this way, than say simply applying it with a cloth and wiping...
