Shorting Switch
Hi, The setup I am using is a Hacker B-50 LMR special motor. I am using an 18-10 prop and I am running 7 2400 mah cells or 10 1700 zapped cells. I suppose it could draw up to 50 amps. I am planning now to install a separate Deans Ultra plug on the hot wire. It will have access form the side of the glider. Reeves.
