Shorting Switch
Hi, I am setting up a 3M Graphite with a Hacker B 50S motor for LMR. Does anyone know where you get the parts for a "shorting switch"? Electric parts stores including Radio Shack don't have a clue about what I am looking for. If anyone knows where I can order this it would be a big help since it definitely is a safety concern. I'm told it should be installed on the hot wire and be able to handle 50 amps. Thanks, Reeves in Alaska.
GA
Don't know if it would qualify as a switch, but why not use an automotive plug-in fuse holder. They're light and compact, making them easy to mount on the side of the plane. Plug the fuse in just before you launch. It would also serve as a protection against a short circuit. The fuses are available for at least 30 amp, maybe more.
The other thing that comes to mind is a phono jack. They make some of them so the contacts short out when nothing is plugged in. You'd have a plug with no wires on it that you would remove just before launching. You might be able to find something at a shop for the high-powered audio systems people put in their cars.
Hope that helps.
Hope that helps.
Hi, The setup I am using is a Hacker B-50 LMR special motor. I am using an 18-10 prop and I am running 7 2400 mah cells or 10 1700 zapped cells. I suppose it could draw up to 50 amps. I am planning now to install a separate Deans Ultra plug on the hot wire. It will have access form the side of the glider. Reeves.
