RCU Forums - View Single Post - Ryobi linkage
Thread: Ryobi linkage
Old 05-21-2003 | 03:13 PM
ANeat's Avatar
ANeat
My Feedback: (15)
Default Ryobi linkage
Sounds like you may need a spacer under the carb if its hitting. You may not even be opening the throttle all the way.
Another option is to remove the throttle arm and re-install it so that it does not hit. Ive seen some install a tiller arm from a nose gear as a throttle arm.
Adam
