3 dumb questions on OS 70 chokes
You don't need to bother with the choke. Put your finger over the exit to the exhaust, turn the prop over 5 or 6 times and the engine should be primed.
Using choke, choke closed for priming, open for starting. The choke should be spring loaded, turn it to close and it should spring back open when you let go.
