RCU Forums - View Single Post - Cutting hinge slots
Old 09-03-2008 | 12:00 AM
Gray Beard
My Feedback: (-1)
Default RE: Cutting hinge slots
Don, I mix my hinges between hinge points and flat hinges. Just depends on the type of edges and what is behind them. On A kit of scratch built plane it is easy to add support where the hinges are going to go. On an ARF you can be stuck and have to use whatever works. The Hinge Points are sure easier to set up!!
