RE: anyone else???
ok, I recant, decent, there decent for the money, lol.
Savage is a GREAT truck, but straight out of he box yu need to put a piece of fuel line in place of the brake arm spring and make it longer than the spring or your fist run will be your last, becase you won't have any brakes with out putting the fuel line in there. also lock tight the motor mounts and drive cup screws. check your radio, we have sold one or two here and there with bad radios out of the box. double check the spur gear mesh. after about 6 or 7 tanks check your high speed needle to be sure it's not leaking fuel, might be bubbling very slightly around the screw head. there were a few other things we've run across but I can't think of them. if I think of them i'll pm you so you know to check them out.
