RCU Forums - View Single Post - Programming 2Ail 2Flap with 7ch FASST RX
Old 09-04-2008 | 09:46 PM
Magna
Default RE: Programming 2Ail 2Flap with 7ch FASST RX
Bax
Let me give you a better explanation on what I want to accomplish. Im flying a glider with 4 servo wing (2 aileron and 2 for flap) with v tail on my Futaba 9CHP on 8 ch rx.
I don't use glider mode, just acro because I still want my throttle on ch3.
Moving to 12FG, I know the transmitter have a lot built in mixes which is great but its also render a specific RX and wasting the channel from 617 to 608.
The manual indicate for 2AIL + 1 FLAP setup, I can use 617 RX. Since I need to drive 2 FLAP servo for my CROW, I will plug my FLAP servo A into ch6 as per stock mixes and FLAP Servo B into Ch7 or AUX/Gear. I will then program the Airbrake and Crow as 2AIL + 1FLAP wing. Once done I will slave Ch7 to Ch6 with link so that Ch 7 will now follow exactly Ch6.
Does the above explain better?
