RCU Forums - View Single Post - problems with pullstart,on baja 5b
Old 09-07-2008 | 09:32 AM
slawhammer
Default RE: problems with pullstart,on baja 5b
ORIGINAL: selena1718
just found out what happened,a couple of fins on the flywheel broke off,got jammed in betweenthats why the pull start wouldnt turn the engine over,unjammed it seems ok now,is it ok to use the flywheel with some fins broken off,theres a couple on the front side and back side broken off,will it effect anything,can i still run it and is there anything i can do to prevent it from happening again,what would cause that,rocks,i do have the outerwears cover on the pullstart, thanks.
So did you did you do the engine screen mod yet?Not only you my friend but for other people as well should do the
screen mod..save ya from buying a new fly wheel when you do not have the extra money to spend...
Enjoy your baja and have fun...AKA Slawhammer
