Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Giant Scale Cars
 problems with pullstart,on baja 5b >
RC Giant Scale Cars For all those who love driving large scale rc cars share your projects or ask questions here.
Old 09-05-2008 | 01:08 PM
Default problems with pullstart,on baja 5b
hi first time out with my new baja,bought off ebay so new to me,anyways,very difficult to start,the baja haS the walbro 813 carb so there is no choke,anyways finally got it started,running great except kept stalling,started it up 3 different times,fourth time,after 2 pulls ,pull start wont pull any more,will i have to take it apart,no idea what happened,not even turning engine over,any suggestions,thanks
Old 09-05-2008 | 01:25 PM
kengentry5000's Avatar
Default RE: problems with pullstart,on baja 5b
Is the rope pulled all the way out and won't rewind into the starter housing?
Old 09-05-2008 | 01:33 PM
no it pulls out a little,and rewinds back ,just not turning engine over,thanks
Old 09-05-2008 | 01:37 PM
Ok..Once you get the pull starter figured out....Now to start your baja with the 813 carb...turn on transmmmiter ..then baja battery on..
now push the clear prime bulb on carb till you see gas in the bulb....now pull the throttle trigger twice...that will squirt gas in to engine..now pull the
pull starter..it should start in a couple pulls..If not give another trigger pull ..then pull the pull starter it should run now...Some times it just takes
about 4 pulls to start...That's what was recommended to me to do with my 813 carb..Mine starts ok...Best to you and your baja....
AKASlawhammer
Old 09-05-2008 | 01:51 PM
JUST BUY A NEW PULL START...PRETTY CHEAP.....
Old 09-05-2008 | 01:55 PM
turbodremz23's Avatar
My Feedback: (16)
go to the DDM website and order the aluminum starter ring (pawl)...it will solve all your problems.
Old 09-05-2008 | 03:52 PM
just found out what happened,a couple of fins on the flywheel broke off,got jammed in betweenthats why the pull start wouldnt turn the engine over,unjammed it seems ok now,is it ok to use the flywheel with some fins broken off,theres a couple on the front side and back side broken off,will it effect anything,can i still run it and is there anything i can do to prevent it from happening again,what would cause that,rocks,i do have the outerwears cover on the pullstart, thanks.
Old 09-05-2008 | 03:58 PM
Selena: Check out my thread I got going..New to 1/5 scale world...I done a screen mod on the engine..I just broke 12 fins off my fly
wheel ..this last week..had to replace the fly wheel...if you got 3 broken you should be ok...AkA Slawhammer
EDIT: Rocks get in form underside of engine...
Old 09-05-2008 | 04:05 PM
thanks slawhammer,ill definatly check out your thread.
Old 09-05-2008 | 07:33 PM
sounds like you brought a baja that hasnt been maintained...
its not a problem though..
if i were you i'ld set a side a day and pull ya engine out,
get a new pullstart they're cheap enough,
clean airfilter well, and reoil,
inspect ya gaskets between the carb and inlet,
inspect ya plug and change if unsure,
re set ya coil gap,
inpect for gaskets blowouts,
inspect fuel tank and lines for spits/leaks, clean clunk filter (inside tank)
refuel with fresh fuel and good 2stroke oil.....
its a real de-motivator when ya engine just wont play the game
so take ya time to get the engine to start and run reliably and that'll help keep ya pullstart from braking often
good luck
Old 09-07-2008 | 09:32 AM
ORIGINAL: selena1718
So did you did you do the engine screen mod yet?Not only you my friend but for other people as well should do the
screen mod..save ya from buying a new fly wheel when you do not have the extra money to spend...
Enjoy your baja and have fun...AKA Slawhammer
