RE: 12X Programming Glitch????
Hey Ian,
Here is what you do.
Same as the 10X.
Inhibit both Aux 6 and Aux 3.
Go to a Program Mix and activate.
Mix is set up as Aux3 - Aux 6. Aux 3 is the master and what channel you want the servo to work from. Aux 6 is where the servo is plugged into.
Set your values and you are good. Check the mix monitor and Aux 6 should move when you are moving the Aux 3 lever.
Call me if you need help.
217-778-7680.
JR
