RCU Forums - View Single Post - Nitro models pusher Bobcat?
Old 09-07-2008 | 12:22 PM
  #3445
opjose's Avatar
opjose
Default RE: Nitro models pusher Bobcat?
I fly mine with a GMS .76 and a Graupner 11x8 Pusher Prop.
Initially I too was having overheating issues as the cylinder head is not in the air blast when the engine is running on the ground.
A laser temperature guage helped immensly.
I noted that the head temp at the plug was exceeding 380 degrees F which is MUCH higher than what I should see.
So I adjusted the high end needle richer until the head temp dropped to 280-300 degrees F which was perfect.
This is one of those things where no amount of listening or taching the engine will help. I would not have thought of it if it wasn't for a friend who offered the use of his laser thermometer. After the very first reading I know what was wrong, and within a few minutes I had the engine operating as it should.
I'd suggest doing the same.
