RCU Forums - View Single Post - A6M5 Zero
Thread: A6M5 Zero
Old 09-08-2008 | 01:28 AM
bokis
Default RE: A6M5 Zero
I tried several props om this engine and APC 17x8 is by far the best one to use for me.. The installation,I cant remember that i had any problems with it except fitting in the cowl with this aluminium bars,the bars had to be mounted first on "the wooden box" and it takes some time to fit that in...
I´ll placed the throttle servo on top of the same box,and glued 2 4cells sub-c pack on each side of the same box..
A little bit of led inside the cowl (I use silicon to glue everything,both led and acc and servo)
The final touch with this airplane is to use a Keleo system with the engine,that is what make this engine sound so good ,thanks Kelvin![sm=thumbs_up.gif]
//Bokis
